Hi there could any one help here with regards to above.I have checked tubing its ok.but i can not hear the pump sound. does this mean motor pump is gone or something else? if so how much does it cost and how much damage a mechanic gonna do to my pocket in manchester?Thanks
manchester you say! haii!
what are you running thru the washer? plain water? when can you not hear the pump? first thing in the morning?
my guess is your running a weak mix of screenwash and its frozen = no pump noise repeatedly pressing the stalk may burn out the pump
  • 2 weeks later...
If you cant hear the pump running could be one of two things either could be as said above the pump gauze has blocked up and full of gunge or the fuse could be blown and will not draw any water up i would first check the fuse for the washers and then if you still cant hear the pump running i would check for voltage down to the pump if there is power then the pump will be faulty
few simple things first though mate as a pump may be quite expensive
