i went a lsd so bean lookin for 1 will this 1 fit in min even tho its not a lsd box TRD Helical LSD and if so do yo half to change the drive shafs thanks if anyone can help me
You are slightly mistaken - the "LSD Gearbox" people refer to that require changing the driveshafts is the optional Viscous-LSD Gearbox available from factory; these utilised a slightly shorter driver-side driveshaft and a different rear engine mount. It is not the gearbox for which an aftermarket LSD is to be installed into - infact, there aren't any aftermarket differentials that can fit into the Optional-LSD Gearbox [well, TRD USED to make them, but very small numbers and a long time ago]
So, yes, the TRD LSD will fit your gearbox on the basis that you don't have the optional LSD Gearbox
