Rhys249 Posted January 20, 2011 Posted January 20, 2011 Hi guys, i've just bought myself a cheap TD04 turbo for the kit i'm making up, i've had a quick search round the forum but i cant find a topic on how to rotate the one side, anyone got any info on doing this ???allso, the turbo i've bought is a TD04 20g, i've read somewhere that a 13g is the best to use, will the 20g be ok and whats the difference ???Any info would be awesome, cheers ! Quote
Whitegv Posted January 20, 2011 Posted January 20, 2011 Hi guys, i've just bought myself a cheap TD04 turbo for the kit i'm making up, i've had a quick search round the forum but i cant find a topic on how to rotate the one side, anyone got any info on doing this ???allso, the turbo i've bought is a TD04 20g, i've read somewhere that a 13g is the best to use, will the 20g be ok and whats the difference ???Any info would be awesome, cheers !sorry to use the other forum here but i see most people on both, theres a thread on tgtt in the awsomly helpful infor section on how to do it ;) Quote
k1r4n Posted January 20, 2011 Posted January 20, 2011 Hi guys, i've just bought myself a cheap TD04 turbo for the kit i'm making up, i've had a quick search round the forum but i cant find a topic on how to rotate the one side, anyone got any info on doing this ???allso, the turbo i've bought is a TD04 20g, i've read somewhere that a 13g is the best to use, will the 20g be ok and whats the difference ???Any info would be awesome, cheers ! hey mate ive just done mine a couple of weeks of ago i rotated both sides i removed actuator and oil/water lines undid the centre vband then using a vice to clamp the compressor side - tapped of the turbo exhaust housing - make sure as it comes off evenly so not to damage the fins when the housing came away - used a dremmel and ground down the locating dowel so it was flush then to take off the compressor side - use a strong and long handled circlip tool and remove the circlip behind the compressor housing once its apart - again being mindful of the fins - grind down the locating dowel again now put it back together in reverse order - keep in mind the oil return points downwards towards sump - and position the compressor housing to suit your fmic or tmicTO DO ONE SIDE JUST TO HALF THE WORK I GUESS BE VERY VERY VERY CAREFUL OF THE FINS ON THE TURBINES MATE Quote
Rhys249 Posted January 20, 2011 Author Posted January 20, 2011 Cheers guys masive help, i'll have a quick look at the one on TGTT aswellwhats the verdict on it being a 20g turbo instead of a 13g ?????? anyone ? Quote
Fro Posted January 20, 2011 Posted January 20, 2011 Just so you know it will probably a fucking mission to split the turbo! I recommend a rubber mallet and some patience! Think people sometimes soak the join in wd40 too before trying to split Quote
Rhys249 Posted February 9, 2011 Author Posted February 9, 2011 hey mate ive just done mine a couple of weeks of agoi rotated both sides i removed actuator and oil/water linesundid the centre vbandthen using a vice to clamp the compressor side - tapped of the turbo exhaust housing - make sure as it comes off evenly so not to damage the finswhen the housing came away - used a dremmel and ground down the locating dowel so it was flushthen to take off the compressor side - use a strong and long handled circlip tool and remove the circlip behind the compressor housingonce its apart - again being mindful of the fins - grind down the locating dowel againnow put it back together in reverse order - keep in mind the oil return points downwards towards sump - and position the compressor housing to suit your fmic or tmicTO DO ONE SIDE JUST TO HALF THE WORK I GUESSBE VERY VERY VERY CAREFUL OF THE FINS ON THE TURBINES MATEJob done ! the circlip was a bastard to get off, i took the clamp off and used a rubber hammer to split the turbo, only problem was i couldnt get the housing past the fins on there i culd still rotate the turbo and there didnt seem to be any locating pins on there, however, the guy i bought the td04 of was a bit of a dick and sent me a td05, the only locating pin on there was on the compressor side so i had to file a little grove in the side for that to sit in Quote
string Posted February 9, 2011 Posted February 9, 2011 menna grind/file the pin off. not make a new hole for the pin to sit in. aslong as it works Quote
Rhys249 Posted February 9, 2011 Author Posted February 9, 2011 menna grind/file the pin off. not make a new hole for the pin to sit in. aslong as it works There was no pin, its hard ton explain but it was a small bit on the inside of the comp housing that you couldnt get a tool in to, the exhaust housing side had nothing atall on it tho anyway its all rotated and seems to be ok, wont be on there long hopefully lol Quote
