ep91steve Posted January 22, 2011 Posted January 22, 2011 My car has started to over heating what could it be 1st time it has done it tempt gauge allways been in middle Quote
Morph Posted January 22, 2011 Posted January 22, 2011 Check to see if the fans cutting in and feel the rad hoses to see if they are both hot buddy for a start. Quote
ep91steve Posted January 22, 2011 Author Posted January 22, 2011 Will a start car to see if fan kicking in Quote
ep91steve Posted January 22, 2011 Author Posted January 22, 2011 A wee bit hot well top one.. Unplug fan and connected it back up Quote
ep91steve Posted January 22, 2011 Author Posted January 22, 2011 Next to st Enoch centre mate how you do that a have no tools Quote
string Posted January 22, 2011 Posted January 22, 2011 on the block theres the temp sensor on the side near where the waterr lines for your turbo go in. there 3 wires in it with spade connectors. just unplug one at a time till the fan kicks in. Quote
ollie ryan Posted January 22, 2011 Posted January 22, 2011 Put the interior heaters to full blast, try get some of the heat away for the engine bay, the fan on my car doesn't work so when im in traffic I just set the heaters to full and it keeps the engine bay cool enough Quote
ep91steve Posted January 22, 2011 Author Posted January 22, 2011 Will a be able to drive it once a have done it Quote
ep91steve Posted January 22, 2011 Author Posted January 22, 2011 It's cold air it's blown and temp gauge is in middle Quote
ep91steve Posted January 22, 2011 Author Posted January 22, 2011 Yeah a see a green plug.. Heaters blowing out cold air Quote
ep91steve Posted January 22, 2011 Author Posted January 22, 2011 Coolant cap was off topped it up with water and rad will it be ok Quote
ep91steve Posted January 22, 2011 Author Posted January 22, 2011 Hot air now and gauge below half Quote
ep91steve Posted January 22, 2011 Author Posted January 22, 2011 A never as coolant cap was off will it be ok now Quote
Wantaglanz Posted January 22, 2011 Posted January 22, 2011 should be fine mate, you will need antifreeze added when you get home to stop it freezing tonight Quote
ep91steve Posted January 22, 2011 Author Posted January 22, 2011 All good now will put anti freeze in rad later? Quote
Wantaglanz Posted January 22, 2011 Posted January 22, 2011 yeah, you might have to drain it first because you just filled it up with water mate Quote
ep91steve Posted January 22, 2011 Author Posted January 22, 2011 Only put about 2litre of water in it a just bought a litre off anti freeze Quote
