Preston Posted January 29, 2011 Posted January 29, 2011 can any 1 help explain what the best type and size of head gasket i would need i did the head gasket cambelt and all top end gaskets when i had a new cylindfer head fitted as my cheap manifold cracked one of the studs off the head . put on a aps head gasket and its been on there two weeks and its leaking oil out above the oil filter , so does anyone know if i need a steel 1 now ive got abit more power? and will i need better head bolts? does it make a diffrence? thanks alot tom Quote
ollie ryan Posted January 29, 2011 Posted January 29, 2011 I personally run a 0.6pm TRD hg I had one on my old engine and now on the new one and it works great, and depending on what power you aim for I would put arp headbolts on invade you decided to go td04 and abit more power in the future Quote
Preston Posted January 29, 2011 Author Posted January 29, 2011 where can i get 1 and how much and can you only use the bolts once are they stretcher bolts?thanks for the help Quote
