Mattb504 Posted February 1, 2011 Posted February 1, 2011 I just put on a HKS FCD i want to run 0.9bar.But when i started it up i had a slight misfire? and engine management light came on?I've put it on number 6 and its stopped mis-firing. Any idea?Cheers (by the way im hopeless at wiring!) Quote
BearFaceOfDoom Posted February 1, 2011 Posted February 1, 2011 I'm shit at wiring too! lol. With the FCD on 6 when does it hit fuel cut?Have you uprated your fueling system? Fuel pressure reg, fuel pump etc? because otherwise your gonna kill your engine running it a 0.9bar Quote
Mattb504 Posted February 3, 2011 Author Posted February 3, 2011 I'm shit at wiring too! lol. With the FCD on 6 when does it hit fuel cut?Have you uprated your fueling system? Fuel pressure reg, fuel pump etc? because otherwise your gonna kill your engine running it a 0.9barHi mate,Yh I've done all that. i just realised a wire was hanging out of one of the blocks going into the ecu! so its all ok now lolCheers anyway Quote
StarletMad Posted February 3, 2011 Posted February 3, 2011 Mine was set on 9 at 1bar when i had a CT9 turbo duno if that helps Quote
