BoGlE Posted February 3, 2011 Posted February 3, 2011 Just got a couple of questions.What psi/bar does the standard actuator on a td04 run at, and can i use the water lines from the ct9 setup with the td04?thanksJoe Quote
whiteglanzav Posted February 3, 2011 Posted February 3, 2011 im pretty sure its 0.8 bar and no u need different water lines and oil lines Quote
BoGlE Posted February 3, 2011 Author Posted February 3, 2011 So i would need to buy a hks actuator to run 1 bar then? Thurt you could use the standard lines haha Quote
ep91steve Posted February 3, 2011 Posted February 3, 2011 You don't need to use water lines on the turbo Quote
BoGlE Posted February 3, 2011 Author Posted February 3, 2011 How come? Its surely best to run with a flow of water through it though? Quote
