can any body help ive had 2 head gasket in two weeks fist was a aps composit cheap standard gasket had it all fitted with new head bolt torqued up properly head skimmed , and it leaked above the oil filter , so reading other peoples post i brought a 0.6mm trd mls gasket arp bolts had it skimmed and torqued up properly again and drove it 20 miles and still leaking in the sazme place ... can anyone help please ????????????????????????????? any ideas on what im doin wrong this is costing alot of money...any help would be much appreciated
its a new cylinder head as the previous garage cracked my last 1 when they fitted my manifold they ripped 1 of the studs out.. i had a good look when it was taken off to skim... could it need a thicker head gasket?
chances are the block is warped then
if its skimmed and everyything is flat then you should have no need for a thicker head gasket so i would say warped block then but i may be wrong
Sounds like a warped block needs checking with a straight edge no signs of it leaking within the cambelt area and running out near where the leak looks to be?
Yeah would be a total engine out and strip to a bear block to have it skimmed or decked as people call it. Mls gaskets require both faces to be morealess perfect otherwise you get leaks like you have unfortunately dude.
Quite dear tbh mate as the engine and box have gotta come out and stripped down then you've all the gaskets and bearings to buy tbh there easy engines to work on dude.
fuck lol.. anyone wanna buy my car as it it ... just spent 1K on fmic, air filter relocaation ,trd head gasket,had loads done . make me an offer as it stands .. i really cant afford to fix it as i have a van to run and mooving out very soon
