string Posted February 13, 2011 Posted February 13, 2011 won't boost over .4 bar. turbos good. ext w/g's good. all mechanical side seems good. just want reassurance of it being a leak. anyone else has issues after swappin turbos over. cheers Quote
string Posted February 13, 2011 Author Posted February 13, 2011 just thought i'd explain a bit more. foot down and seems to take ages to spool to .4. i know going from a hybrid to td series will be a bit laggy. so with it taking ages to spool, ext w'g opens a little but only heard a proper scream once. all the other time it opens a touch. flutters aswell so boost is being produced. boost leak or not? cheers Quote
Sparky Posted February 13, 2011 Posted February 13, 2011 So you fitted a new turbo?Was gonna ask what spring is in the wastegate, go through all your intercooler pipes must be a leak somewhere Quote
Lee_EP82 Posted February 13, 2011 Posted February 13, 2011 Before i had mine mapped i had it running off wastegate spring and max it managed was 0.38 bar going off a 0.5 bar spring due to the little loss you get from fmic.Is yours set up to run off wastegate spring? Quote
Dean @RW-Developments Posted February 14, 2011 Posted February 14, 2011 was going to say the same mine only boosted on spring pressure at 0.4 so i turned it up to .5 with mbc made a hell of a difference.Dean Quote
string Posted February 14, 2011 Author Posted February 14, 2011 ok thats cool. i was proper bummed aboutit not making more boost. watsgate is supposedly a .7/.8 spring. yeh it straight of compressor to ext w/g nipple. so mbc on to see if it makes more boost then get ebc? any recommendations. cheers guys Quote
