Whitegv Posted February 22, 2011 Posted February 22, 2011 there are 2 pipes coming from the standard actuator. one goes to the turbo and the other to the hi-lo boost solenoid yeah?as i have removed the solenoid from the circuit.the problem-it was set up exactly the same before on the old engine. i have one pipe going to the turbo and the other one just to the atmosphere. but it will not release the wastegate, it boost up to fuel cut and would go further. all i have done is removed the metal pipe that connects to the other actuator pipe (not the one that goes to the turbo) and goes up the side of the cam cover. so im just left with a 3inch bit of vac pipe coming from the actuator.will the actuator be broken or something to do with the pipes? seems odd as it was working perfect 4 days ago on exactly the same turbo and actuator.help realy appreciated Quote
