Heya guys,
My engine makes this really wierd sort of whirring noise at about 900-1200 revs..
Have a listen to the video carfully and see if you can hear it..
What ya think it is? anything bad??
Thakns, dan
Mine makes a similar noise, its just the belts driving the pumps, alternator etc. I wouldnt worry about it, just check your belts are in good condition, including your cam belt.
Heya guys,
Thakns, dan
Hey guys thanks for the replies,
Yes the cambelt was changed 100 miles ago adn the tensioners where done with this!
I will check the belts tightness tommorow morning.. What should they be at? anyway to check if they are too tight?
Dan
mine makes same noise mate,,,i assumed it was a noisy tensioner. like mentioned check tightness of belt, were the belt runs up the left towards the cam pulley u should be able to twist it 90 degrees, no more no less, a simple way of checking it.
