sorted that out it revs now,
but it wont boost, ive put my td04 kit on, everythings right as far as i know, got an external wastegate, and the vac pipe goes from the turbo compressor housing to the bottom connection on the wastegate, the one nearest the exhaust inlet side, this is right isnt it?
coiuld there be anything else stopping it from boosting? it spools up when i rev it with the car in neutral but doesnt want to boost when engine is under load?
Are you running off the spring ?
yeah no boost controller as yet, ive looked on turbo smarts website, the vac pipe is connected properly, i cant hear any leaks coming from the system at all.
Have you left the other connection open to vent?And is the wee metal ring in between mani and wastegate?
yeah both exactly as you say, i cant hear any leaks but i will see in the morning if theres anything coming out the screamer when its in garage, internal wastegate is welded shut and i cant see that coming open but il check as well. cant make it out at all
Try running the vaccum from the inlet mani.Thats where mines runs from.Cant see you having a problem running it from where you are running it tho.
