string Posted March 10, 2011 Posted March 10, 2011 http://www.ukstarletclub.com/forums/index....showtopic=38168i have 2 wires left.one is called fcd in which is meant to go to sensor.other is fcd out which goes to ecu. do i just use the above diagram? no instructions in manual or on there site. cheers Quote
Lee_EP82 Posted March 10, 2011 Posted March 10, 2011 I haven't got that 1 but i take it your gizzmo acts as a fcd aswell?Then yer wire it how the diagram in the above link says. But make sure you get the fueling checked. Quote
string Posted March 10, 2011 Author Posted March 10, 2011 i'm runnin emb aswell mate. if it don't need wiring in i might leave it. how will the turbo timer work? off the ignition power cables that i've spliced into like it said. cheers bud Quote
k1r4n Posted March 10, 2011 Posted March 10, 2011 Am I missing something here boys?the thread says gizzmo ms ibc 2 wiring - which is a boost controllerso why are you talking about ecu's and fcdi have a gizzmo too and all it needs is ignition power ground and 2 wires to the solenoid and then vacuumsthere are 2 extra wires for a button - not that u have to use them Quote
Lee_EP82 Posted March 10, 2011 Posted March 10, 2011 The MS2 has functions for turbo timer and fcd!I wouldn't bother wiring up fcd then with the emb. An turbo timer wiring does as it says i've never fitted 1 mine was on my car when i bought it sorry. Quote
string Posted March 10, 2011 Author Posted March 10, 2011 have you got the gold one mate? with turbo timer and fcd etc.? does the turbo timer work of ignition wires. also i was asking if i need to wire the fcd in if i'm running emanage Quote
k1r4n Posted March 10, 2011 Posted March 10, 2011 have you got the gold one mate? with turbo timer and fcd etc.? does the turbo timer work of ignition wires. also i was asking if i need to wire the fcd in if i'm running emanagei'll be honest i havent connected mine up yet and ive got the black one with multi scramble - which obviously is the older model so my bad Quote
Lee_EP82 Posted March 10, 2011 Posted March 10, 2011 Mine doesn't have turbo timer or fcd mines the black ms-ibc im guessing the same as kiran's tbh. Quote
string Posted March 11, 2011 Author Posted March 11, 2011 where did ya wire yours into lee? dunno where the best place will be. cheers Quote
