I dont quite understand what you mean buddy? Are the two 19mm holes too high or too low?
If too low then jack up the wishbone until you raise them into place and then just give them a goood push to get em in and if too high, that i usually get someone to push down on the hub while i try push a bolt through....
Dan.
The bit on the on the hub won't go into the coilover to put the two 19mm bolts in place. And there's no were to bolt the brake lines on to the coilovers (d2s)
Ahh yes you mean it feels liek the big piece of metal doesnt fit into the coilover? I remember when i had my D2's and i had to bash it in with a hammer or i may have tried to prize open the part on the coilover slightly :wub: But first just put a cloth over and bash it :o
just cable tie it to the coilover. ave got the brake line brackets for d2's lying about sumwhere if your interested
take the top shocker nut off of the bottom bracket and then put the brakeline bracket on then refit nut. simple. a never used mines but have them in the box. dont need them now as hav meister r
