fuel a td04 at 1.2? or best searching for 330s? also eventually i will go td05 so 550s will be in order. wait till the time or get them now. just wondered bout mappin a td04 at 1.2 with 550s might be a pain.
  • 2 weeks later...
Im going TD04 very shortly String mate. I'll be running 1.2 bar on stock internals.
From a few conversations I've had with Jay and Chris, standard injectors can be used for the TD04 as well variants of 315c, 330cc, 370cc etc etc. It will all depend on the setup (i.e what boost you will be running, in your case 1.2bar and your map/fueling) In theory larger injectors are only needed if you need the additional fuel delivery or your current ones are maxing out at max duty cycle which is pushing them quite hard. If in real doubt talk to your tuner or if tuning yourself, someone who does tuning.
I've just got my mitts on a set of denso 370cc as recommended by CCM. Can't wait!
Joz
