Sparky Posted April 18, 2011 Share Posted April 18, 2011 Wideband just turned up seems pretty straight forward to fit although I need to ask which colour wires go where as I cant remember.Red is obviously 12v liveBlack is groundOrange- Ignition live????White- Illumination?????There is also another plug which goes into the control unit with a green, brown and black wire any idea what this is for?Also when calibrating it does the car need to be upto temperature and running?Thanks Lewis Quote Link to post Share on other sites
Sparky Posted April 18, 2011 Author Share Posted April 18, 2011 According to the poor instructions the other loom with the green black and brown wires are as follows:Black is groundBrown is Wideband analog output 0v-5vGreen is Narrow band analog output 0v-1vDo I need to wire in the narrowband wire? And what pins do these go on the ECU? Quote Link to post Share on other sites
Fro Posted April 18, 2011 Share Posted April 18, 2011 What make is it? I've just installed my aem one, was pretty straight forward as I only used the live and ground as I won't be using it for data logging Quote Link to post Share on other sites
Sparky Posted April 18, 2011 Author Share Posted April 18, 2011 Its a prosport one, all sorted now Quote Link to post Share on other sites
addz Posted April 18, 2011 Share Posted April 18, 2011 Glad you sorted it mateWhat make is it? I've just installed my aem one, was pretty straight forward as I only used the live and ground as I won't be using it for data loggingCan I pick your brains a bit, do the AEM ones need calibrating? Quote Link to post Share on other sites
Fro Posted April 18, 2011 Share Posted April 18, 2011 Glad you sorted it mateCan I pick your brains a bit, do the AEM ones need calibrating?No, just fit it and away you go, self calibrating apparently. 99% sure anyway, I'll check my instructions cause it tells you how to calibrate it for one reason or another! I'll get back to you! Quote Link to post Share on other sites
nazzurro19 Posted April 18, 2011 Share Posted April 18, 2011 i have defi gauges and they have a red,black,orange and whiteso to get em to work just so i can test them .. would i just have to hold the orange n red on the pos + batt terminal and the black on the neg - battery terminal ? Quote Link to post Share on other sites
Sparky Posted April 18, 2011 Author Share Posted April 18, 2011 Yea that would be fine mate Quote Link to post Share on other sites
