jham Posted April 21, 2011 Share Posted April 21, 2011 Hello all, my car has just started knocking recently.It only seems to be on full lock when i start pulling away from low speed.I get a large knock/ clunk from rear, then nothingAnd same from front 2 strust depending which way i turn.Once i start moving i get no clunks knocks at all even when on full lock. its only when i stop then pull away again it will do it once for the first time i lock that direction if that makes sense.I have brand new Meister Rs fitted so dont think it will be top mounts?any idea people Quote Link to post Share on other sites
DarkJackal Posted April 21, 2011 Share Posted April 21, 2011 jham said: Hello all, my car has just started knocking recently.It only seems to be on full lock when i start pulling away from low speed.I get a large knock/ clunk from rear, then nothingAnd same from front 2 strust depending which way i turn.Once i start moving i get no clunks knocks at all even when on full lock. its only when i stop then pull away again it will do it once for the first time i lock that direction if that makes sense.I have brand new Meister Rs fitted so dont think it will be top mounts?any idea peoplePossibly CV joints buddy?Check your outer boots for rips/tears also Quote Link to post Share on other sites
jham Posted April 21, 2011 Author Share Posted April 21, 2011 yea thats hat i was thinking, dont realy no why i posted suppose i just need to get her up in the air and investigate, will defo check the outer boots tho, cheers Quote Link to post Share on other sites
DarkJackal Posted April 21, 2011 Share Posted April 21, 2011 jham said: yea thats hat i was thinking, dont realy no why i posted suppose i just need to get her up in the air and investigate, will defo check the outer boots tho, cheersno problem buddy, report back Quote Link to post Share on other sites
