Simply put... No
You wouldnt have anywhere to port it. The Glanza rocker cover has the port in between the leads which is what is used to link it up. You could do it for show.
your wrong there is also a port on the n/a rocker cover just in a diffrent place
you put a pipe from the pcv valve (green plastic right angle thing) and other pipe onto the metal pipe off the rocker cover(top right of the rocker ) put them into the catch can the there will be a vent pipe off the catch can let it dangle towards the ground
Yes there is a point :D
i had a DIY one on mine caught a reasonable ammount of oil, kept the inlet manifold clean and the main advantage is the intake mixture of fuel + air isnt polluted by the oil vapour
i placed the catch can inbetween the pvc and the vac port on the inlet
