so ive put a front mount on it, de-cat, shorter inlet route and its running 11.5 psi (restrictive wastegate). no power steering and no aircon. 150 bhp seem about right?? what do you suggest next to do?? wanna keep under fuel cut for the minute but would like to see a little more power.
Ow i see now :)
FCD and put it on a Bar ;) and get a wideband so you can see if the air/fuel is okeey when you put it on a bar :D
And if it than is not on 11,5 on the wideband you can get a fpr so you can adjust the fuel :D
