My TD04 oil exit pipe is leaking to the sump, seems te TD04 pipe is much smaller so the original pipe isnt working.
Where can i get one to replace this, obviously it needs to be thinner to fit the turbo and thicker to fit the sump!
Suggestions
Cheers
Craig
Alot of those places on ebay don't recommend using the hose for continuous flow of oil but if it's stated that it does it should be fine.
I bought mine from this place, http://www.sfsperformance.co.uk/reducing_elbows.asp#ninety
They do ones suited for oil but I can't find them on the website so maybe best to phone. Only reason I would recommend them is mine took two weeks to get to me and the boy was an unhelpful little wanker but worth a bash if your stuck. Iirc the reducer you need is 19mm-16mm??
