glanza97 Posted May 30, 2011 Posted May 30, 2011 I have some prosport gauges with a warning function and im wondering what would be a good pressure and temp to set the warnings at incase i do ever have any problems...Thanks guys Quote
Taggy Posted June 1, 2011 Posted June 1, 2011 I am about to connect up my prosport dials too and have the same problem, just run the car to normal operating temps, take a note of the oil pressure and oil temp and use them as a base.Give the car a good booting down the motorway, say 100mph and take note of the readings, so you have a maxiumum and normal operating temps then and use those a guide.Mine is going to be used on track so i'll check for you too if you like rather than you speeding on the motorway lolI have some prosport gauges with a warning function and im wondering what would be a good pressure and temp to set the warnings at incase i do ever have any problems...Thanks guys Quote
