Long story short, fitted a td04 kit... using a vf24 turbo, cant get any boost atall! 0 PSI.... i connected a vacuum pipe from turbo straight to actuator for full boost, still 0 psi.....?!? can anyone please help?!
I am also having a problem were sometimes if i stall the car, turn back on...hit the revs, revs drop back down and then car cuts out...
if i had the vacuum/water pipes on the inlet mixed up would that make sense?
someone help please?
I also have a pipe with filter from the back of the inlet going to (what i think is the map sensor) but then their is also another pipe connected that doesnt go anywhere? obv if i take my finger off this pipe the car revs high...
Thankyou in advance
  • 4 weeks later...
