Taggy Posted June 2, 2011 Share Posted June 2, 2011 I have been starting to drive my car harder now to make any problems show their ugly face (so not to waste a day on track with some stupid problem)Today as the weather was nice i went for a spin up the valleys with the intention of driving harder to show up any sneaky leaks etc.To my supprise i managed to spring two leaks 1. Looks like the gasket is screwed on the TD04 oil return pipe off the turbo, so just ordered a new one2. I have sprung a water leak from the back of the engine, are there only two water hoses on the back of the engine, i was having alot of difficulty locating where the water is coming from. Quote Link to post Share on other sites
daz gt turbz Posted June 2, 2011 Share Posted June 2, 2011 theres the 2 heater matrix pipes and the one from the water pump that comes round into the thermo housing. defo from the back of the block and not back of water pump? Quote Link to post Share on other sites
Taggy Posted June 2, 2011 Author Share Posted June 2, 2011 It seems to be coming from the far left corner of the engine on the back, i know the matrix pipe is there but i couldnt feel any water when checking the hose.Will take the bugger off and inspect the hosestheres the 2 heater matrix pipes and the one from the water pump that comes round into the thermo housing. defo from the back of the block and not back of water pump? Quote Link to post Share on other sites
daz gt turbz Posted June 2, 2011 Share Posted June 2, 2011 left corner if you were looking at the engine from the back? (dizzy side) Quote Link to post Share on other sites
Taggy Posted June 2, 2011 Author Share Posted June 2, 2011 lol sorry, no the other side if your looking from the front.left corner if you were looking at the engine from the back? (dizzy side) Quote Link to post Share on other sites
daz gt turbz Posted June 2, 2011 Share Posted June 2, 2011 water pump side then! is it leaking all the time or just on load? Quote Link to post Share on other sites
Taggy Posted June 2, 2011 Author Share Posted June 2, 2011 Its the first time i have seen it leaking, plus its also the first time i have driven hard with this engine, before that i have just been giving the odd 10 secs of boost up the road testing out stuff. Where abouts is the water pump situated, when i was underneath it looked to be dripping off the ridge of the sump where it meets the bottom off the block.It doesnt leak on idle, great i hope its not the water pump, how hard is it to change?water pump side then! is it leaking all the time or just on load? Quote Link to post Share on other sites
daz gt turbz Posted June 2, 2011 Share Posted June 2, 2011 the water pump is the other pulley that runs on the same belt as the alternator (if that makes sense?!?!) if its leaking all the time when running it sounds like it could be the water pump being that side of the engine. Quote Link to post Share on other sites
miib14 Posted June 2, 2011 Share Posted June 2, 2011 yep sounds like waterpump or maybe the hose going to the waterpump... Quote Link to post Share on other sites
