The Toffinator Posted June 4, 2011 Posted June 4, 2011 Current set up in my car is a set of standard sized front alpine speakers, and some expensive 6x9s in my parcel shelf. sounds brilliant now but am looking for a bit more kick, and want to fit an amp.Only thing is i want it under the passenger seat so its stealth installed, and want a small one so it fits nice under there. Main question is what channel amplifier do i need? will a 2way be okay? or is there any you would reccomend? currently looking at this little one http://www.caraudiocentre.co.uk/product_m-...490_p-23379.htmThanks! Quote
200bhp starlet Posted June 4, 2011 Posted June 4, 2011 that amp would be fine mate if you only want the 6x9s off it if you wanna run fronts off it too you need a four channel but the standard size fronts dont really need an amp as there so small if it was me i would just crank the 6x9s up with an amp you can adjust the fade on the head unit so you can turn it right up without the fronts popping lolhope this helps lewis Quote
The Toffinator Posted June 4, 2011 Author Posted June 4, 2011 Ah that makes sense, amplify the rears and turn the fader to the back should be right. will have a go i think! Quote
200bhp starlet Posted June 4, 2011 Posted June 4, 2011 it will def sound alot better mate get a cheap wiring kit too if you aint already got one Quote
