wonder if anyone has the same problem as a friend of myne, he has a 96 Glanza, i have a 97 Glanza, i gave him my drivers side hub and he fitted it all up but it is not the same as the passenger side? the wheel sticks out fair bit more than the passenger side as if its a totally different hub.
as far as we know, you would have thought they would of been the same size?
is the earlier/later Glanza or even GT hubs different in size?
Thanks dan, ive measured the distance from the 2 bolts of the coilovers to the edge of the disc and my hubs its 10cm and on the other it 11cm, also the steering is way off but that would be because the hubs sticking out further.
The only way i can see is just to get another hub, but wondered why theres such a different between the 2 hubs.
Any help/ info would be great.
