little lews Posted July 13, 2011 Posted July 13, 2011 Well just fited my blitz ecu and i was runin 4 barOf fuel on my stanerd ecu can i turn it downnow and if so wot to do anyone no and wots the diffrenswith this ecu and my stanerd 1 any help would be topthanks Quote
nazzurro19 Posted July 13, 2011 Posted July 13, 2011 well the blitz ecu will remove fuel cut, rev limit raised to 8k ish , speed limit is removed and is much more agressive but just get fueling afr checked before boosting at a bar +also im not sure on fuel pressure bar wise Quote
little lews Posted July 13, 2011 Author Posted July 13, 2011 Ideal thanks bud i got it on the rr today at 1.2 bar today andgot 231.5 and the clutch started slipin im goin to get it mapedwith the blitz ecu and keep the emb on in aswell for a finermap lol Quote
nazzurro19 Posted July 13, 2011 Posted July 13, 2011 well if i was y uf uve got a blue sell the blitzwhat engine turbo u running Quote
little lews Posted July 13, 2011 Author Posted July 13, 2011 I've done loads mate its td04 on standerd inturnows Quote
nazzurro19 Posted July 13, 2011 Posted July 13, 2011 same ere ive got a blue standard internals td04 kit short shifter etc hu mapped urs Quote
LeeG Posted July 13, 2011 Posted July 13, 2011 as been said u would be better off selling then blitz ecu and get the emb fitted and mapped to suit your car as im sure i read sumwhere they either dont work together or dont work well together, or sell the emb as sounds like the blitz ecu is workin well for u. Quote
little lews Posted July 13, 2011 Author Posted July 13, 2011 There both fited but ant had the emb mapedyet i only fited the blitz ecu last nite and put it on the rrtoday and it stared to slipin I've got a short shifter magnecore 8.5 ledstd04 to much to list mate i cant sell it cus i done a deal with mystanerd ecu Quote
LeeG Posted July 13, 2011 Posted July 13, 2011 if i was u i would sell the emb and buy a clutch mate as if its slipping the now. Quote
ecksjay Posted July 19, 2011 Posted July 19, 2011 If you've got a emb, you don't need the blitz. The blitz is a premapped Rom, cant be changed. Pointless if you have an emb, completely pointless.Sell the blitz, but a clutch and get the emb mapped. Sorted. You'll prob have change left also.The blitz is very basic and not mapped for a td04 however, so don't run it on its own as you will run lean. Quote
little lews Posted July 20, 2011 Author Posted July 20, 2011 I had it on the rr the over day and it did lean off at 6k Quote
