HAZ_EP1991 Posted August 2, 2011 Posted August 2, 2011 Hi lads, recently acquired a apexi power fc ecu with the boost control kit etc. It has a 3 bar map sensor which replaces the standard sensor. It seems to be the red wire on the map sensor has been clean cut off so the red wires in 2 pieces at the moment? wondering if theres a reason behind this being cut off or if i should solder it back together. previous owner doesnt have an idea said he just ran it like that. hmmm Quote
HAZ_EP1991 Posted August 3, 2011 Author Posted August 3, 2011 Red wire = Power. I dont think the previous owner was even running the Map sensor if the red wire was cut off :/ . Soldered back together and fitted Quote
