Taggy Posted August 8, 2011 Posted August 8, 2011 I have got a HKS actuator which was from my CT9 Setup, however since going TD04 i had to cut the arm length so it would give me more room to wind in the actuator arm.Somone mentioned somthing about a stronger spring is needed for a TD04, anyway i have noticed that my actuator doesnt seem to be holding the boost properly and I have had to wind it in more to maintain the same level.Which HKS actuator would i need to replace it?Will be running between 1-1.1bar Quote
