sam2kk8 Posted August 13, 2011 Posted August 13, 2011 basically oil leaks out all the time..all over the driveshaft, wheel, wishbone (probley the belt splashing it about?) anyway i was told its probley the housing so i went along the lines of changing the gasket and using some seal..removed oil filter...then removed that 27m nut but where do i go from here?? should there be a gasket there? and where do i put the sealant? Quote
