jonny1505 Posted August 16, 2011 Posted August 16, 2011 what are these turbos like . what boost can they hold . might swap it with a td05 16 g as i was ment to get one instead of this Quote
Glanza_cl Posted August 16, 2011 Posted August 16, 2011 Erm well its a reeealy old turbo in terms of design and general age, they where used on the JDM Legacy RS between 89-93.Not really meant for big power and will produce no more then a modern mapped TD04 imo. I would defiantly get a 16G over the VF12. you can pick up a good condition Subaru 16G with the bend on the intake housing still there which i think is handy as you can run a front mount filter right from the turbo.A good Google search will probs bring up alot more then my vague knowledge will tell you Quote
jonny1505 Posted August 17, 2011 Author Posted August 17, 2011 Erm well its a reeealy old turbo in terms of design and general age, they where used on the JDM Legacy RS between 89-93.Not really meant for big power and will produce no more then a modern mapped TD04 imo. I would defiantly get a 16G over the VF12. you can pick up a good condition Subaru 16G with the bend on the intake housing still there which i think is handy as you can run a front mount filter right from the turbo.A good Google search will probs bring up alot more then my vague knowledge will tell youI searched nd was basically tho the same swapped it for a td05 16g anywaythis can be locked Quote
