xx YICK xx Posted September 13, 2011 Posted September 13, 2011 Anybody know where the red and blue wires go ????.....The instructions are for the old type coil, Thanks Quote
nazzurro19 Posted September 13, 2011 Posted September 13, 2011 well i thought red for pos+ and then the blue for ya signal i.e into ya ecu Quote
xx YICK xx Posted September 13, 2011 Author Posted September 13, 2011 well i thought red for pos+ and then the blue for ya signal i.e into ya ecured...coil+blue..coil-black.groundThats all i got, Dont wanna risk tryin different places lol, Thanks anyway Quote
nazzurro19 Posted September 13, 2011 Posted September 13, 2011 omex wiring diagramsDistributorless Systems - Use the tachometer output from the ECU, or one of the coilnegative connections. For dual coil vehicles ALWAYS set the number of cylinders to two.RED WIRE Connect this to the coil positive (+) terminal. If this is not easily accessiblethen this wire can be connected to any positive feed that is switched bythe ignition switch.told ya ;) Quote
xx YICK xx Posted September 13, 2011 Author Posted September 13, 2011 omex wiring diagramsDistributorless Systems - Use the tachometer output from the ECU, or one of the coilnegative connections. For dual coil vehicles ALWAYS set the number of cylinders to two.RED WIRE Connect this to the coil positive (+) terminal. If this is not easily accessiblethen this wire can be connected to any positive feed that is switched bythe ignition switch.told ya ;) Thanks very much mate, Would you know the pin-out number by any chance if its no trouble, Thanks Quote
