Taggy Posted September 17, 2011 Posted September 17, 2011 I am gonna be looking for coilovers for the ep70 soon, does anyone know if the coil overs on my GT are a straight swap on the EP70?Or if they actually make a specific set of coilovers to fit the ep70 Quote
Taggy Posted September 17, 2011 Author Posted September 17, 2011 Cheers EnzoYes a straight swap Quote
mech5107 Posted September 17, 2011 Posted September 17, 2011 Cheers EnzoNope! Fronts top mounts need small modification...Actualy you have to drill the midle holes to increase the distance between them. Nothing serious though...just a litle drill work...rears fit 100%.Keep in mind that the fronts should be adjusted a bit higher than when in ep2/91, cause in 70 it will be too low. Quote
