might just be a turbo *puff* which is common on pretty much all turbo cars ;)
check your manifold/down pipe(or cat) are both done up tight
check you've got oil
unless it's pouring out it's nothing to be too concerned about!
  beatz said:
need for info on it mate than that, that issue could be anything ... could be as simple as the oil used is too thin ...
It'll be nothing to do with the oil if it's black smoke, oil issues come out as blue smoke. It'll 100% definitley be fuel if it's black.
mine does it a little, only just started doin it though and only when i give it a load of shit. but she still flys, i'm saying fuel somewhere, not oil (always check it).
you look after her and she'll look after you
