My volt meter and tach came in the post today, but the wires are no where near long enough, i know where to wire both for the 12v power supply, im going to do it in the stereo because it has a wire that says 12v ignition :mellow: so i know that will work fine, then ill earth it somewhere and with the tacho i know that you can get a spade connector to go into the diagnostics box etc. and the volt meter goes to the (-) battery? but anyway how can i extend the wires im assuming i can just get some red wire for the power, black for the earth and negative battery. but what about the green wire for the actual revs? will any wire do? because it all looks the same too me :wub:
