Rajaaaaa Posted April 12, 2007 Posted April 12, 2007 has anyone ever noticed a blank plug infront of the of the radior on the uk EP91, thats not connected to anything, does anyone know what its for?used a probe on it to check any current coming through, no current at all Quote
Blue Icarian Wings Posted April 12, 2007 Posted April 12, 2007 I presumed it was for front fogs. I can't thing of anything else really Quote
Rajaaaaa Posted April 12, 2007 Author Posted April 12, 2007 thts wat i thought, but i put probe on it, no current running thorugh, even with the headlights on, and rear foglight switch turned on, you got same plug aswell? Quote
Glanza_Ragger Posted April 13, 2007 Posted April 13, 2007 its more than likely front fog plug..the uk spec has the front fog wiring inside the dash, but obviously no front fog light button.the wiring is there though incase you decide to fit a foglight setup, all you need to do is trace the wires back and fit a toggle switch. Quote
Blue Icarian Wings Posted April 13, 2007 Posted April 13, 2007 Dig out the manual, figure out where the front fog switch is, hunt around that area Quote
Glanza_Ragger Posted April 14, 2007 Posted April 14, 2007 they dont have fog light switches matey, the loom and connector is behind the dash, juust above the speaker.you can buy a switch from maplin or the glanza one from toyota for a few quid and hook that up Quote
Blue Icarian Wings Posted April 14, 2007 Posted April 14, 2007 Left or right? I presume right so it's near the driver, any pics of what the plug looks like that end?thanks Quote
Glanza_Ragger Posted April 14, 2007 Posted April 14, 2007 its on the right hand side, where theres 2 little blank gaps near the steering wheel on the dash, one gap is for fog light switch on a glanza and other is electric mirror adjuster dial. Quote
Blue Icarian Wings Posted April 14, 2007 Posted April 14, 2007 On the N/A's we have a rear foglight switch on the right, the middle one is a dial to adjust the headlight angle (left is blanking plate for mirror switch) I always wondered what you lot had instead of a headlight dial Quote
