this is for my brother as he needs to replace front and rear lower wishbone bushs what i need to know is
they do different sizes for both
rear bush they offer 35mm long mount bracket or 50mm long mount bracket
front bush they offer 34mm OD or 31mm OD
What size is correct?
The Glanza is 96 to 97 on a P reg
he ordered the front ones from sumo and they said its 34mm required but im not 100%
any info would be a great help
31mm are the ones you need for the front of the wishbone/lower control arm on the EP91, 34mm on the EP82.
If you don't have an anti-lift kit (whiteline etc provide the rear bushes with the kit) you may well need bushes for the rear of the wishbone (EP82/EP91 universal 50mm size).
cheers
shavnh
cheers
shavnh
Rear ones are 2 sizes so what size does he need?. he does not want the anti lift kit.
http://www.priracing.com/product.php/2613/...r-50mm-bracket-
http://www.priracing.com/product.php/2614/...r-35mm-bracket-
