As above please can you advise and give me your prices for engine parts for rebuild of 4e. Blocks already been machined for wiesco 75mm pistons.
1x toyota oil pump (seal on pump)
1x toyota water pump
1x toyota full engine seal and gasket kit
1x rotor cap and arm
1x cam belt kit
arp head bolts
arp main bolts
1x athena head gasket 1.2 or 1.4
(with the head gasket the block has been machined for wisco 75mm pistons and is going to be running a td04 kit and max boost he is going to run is 1.4-1.5 please advise on what you would recommend)
what conrods would you recommend scat or PEC? i understand that scat rods you have to notch the block???
Please pm me with prices and your advise
Many thanks
