garbla900 Posted December 6, 2011 Posted December 6, 2011 Hi I'm just re-doing my engine and I don't know the cylinder head torque down sequence. I'm also needing a guide to redo my engine timing. Even if someone can point me in the right directions it would be much appreciaterd. Thanks in advance Garbla900 Quote
Asad Posted December 6, 2011 Posted December 6, 2011 Check on tgtt bud apparantly theres two ways of doing the torquing....what timing? Timing belt or ignition timing? Quote
Asad Posted December 6, 2011 Posted December 6, 2011 Iirc the cam pulley is at the 12 oclock point at the 4e mark and the crank notch is at 2oclock-ish with the crank pulley showing 0 on the timing belt cover when assembled Quote
