Taggy Posted December 9, 2011 Posted December 9, 2011 Bah why is nothing ever straight forward!I have got a greedy FCD but im having problems with it, i just wired it in and when i start the car the engine management light wont go out and its running rough.I removed the FCD and the problem goes away, am i wiring it in wrong. Here is a pic of it, i just copied the way it came off the other loom, im confused!!There is a Black, Red, Green and White wireNow I am under the asumption Red is positive, black is negative and the green and white wires are the ones which tap into the boost sensor, or what ever sensor it is ;)I put that one into the lime green wire which it was in originally, i checked the diagram from another FCD to make sure, but it wasnt the same brand so wasnt sure if it was correct.Anyway with the FCD in its running crap, i must be doing somthing wrongSuggestions? Quote
Taggy Posted December 9, 2011 Author Posted December 9, 2011 Plus another thing, i assume my car will now hit fuel cut without this installed, is that safe to do so? The rest of the fueling mods are still in place. I want to do some "Testing" tonight ;)I just took it up the road and without even giving it much beans its a bloody rocket ship and for some reason the turbo sounds 10x louder too, sounds like a plane taking off, possibly a leak not sure yet, which is why i want to go back out ;) Quote
Taggy Posted December 9, 2011 Author Posted December 9, 2011 Hahaha what a minge, i just found out that the green wire on the map sensor needs to be plugged in the correct way around on the FCD, i had it back to front!Will sort it tomorrow now ;)Plus another thing, i assume my car will now hit fuel cut without this installed, is that safe to do so? The rest of the fueling mods are still in place. I want to do some "Testing" tonight ;) I just took it up the road and without even giving it much beans its a bloody rocket ship and for some reason the turbo sounds 10x louder too, sounds like a plane taking off, possibly a leak not sure yet, which is why i want to go back out Quote
Taggy Posted December 9, 2011 Author Posted December 9, 2011 yeah i posted up for an answer, and then answered my self with a solution!! Quote
