Its time to do my valve stem seam seals, are they just push on type seals or do you need a tool?
Also is there any good valve stem seals on the market other than going toyota and this is a bit of a silly question but are ep82, ep91 seals the same, just thought i would ask lol.
Any little tips or hints for fitting these or are they the same job as on any other cylinder head?
Any help is greatly appreciated.
Thanks.
Are you going to take the head off and do it? yes they just push on when the valve spring is off
there are uprated ones avaliable on tgtt, ep82 and ep91 are the same
only real advice is make sure you put some clean engine oil on them when you put them on and dont get the buckets mixed up (label them in a egg box)
Thanks mate have done a few cylinder heads in the past, but advice is always handy.
