K24_glanza Posted February 7, 2012 Posted February 7, 2012 In the process of an ep95 turbo conversion and my fuel pump wont run at all. Checked my wiring and it seems ok. Has anyone had a similar issue or have any ideas?Hopeing for something obvious or going to take the pump out and go through the plug with a multi meter.Cheers peter Quote
K24_glanza Posted February 16, 2012 Author Posted February 16, 2012 Done what you said and the pump runs fine then tried to start it with no results. So i took out the spark plugs and turned it over with the pins un bridged and the fuel pump runs for a short period straight after I turn the ignition back to position 2. I am totally confused. Any one got any ideas? Quote
K24_glanza Posted February 18, 2012 Author Posted February 18, 2012 No it doesnt start with bridge left in. I think I could have more than one problem. I am a bit fed up with it at the moment but Going to have another go on monday and check the spark plugs are actualy sparking Then update this. Cheers for the help very much appreciated. Quote
K24_glanza Posted February 21, 2012 Author Posted February 21, 2012 I have a bad earth when I got to positon 3 on the ignition. Got no idea what it is but it causes it to turn over really slow. Quote
K24_glanza Posted February 25, 2012 Author Posted February 25, 2012 All sorted didnt have enough earth cables connecting the engine to chassis. She is running sweet now. Quote
