nordonian Posted April 27, 2007 Posted April 27, 2007 I bought a set of dtm mirros, and was advised to go for mk3 astra base plates. I tried fitting them today, but the base plates dont match up to the rubber seal behind the old mirror. Is the only thing i need to do source a set of rubbers from behind m3 astra wing mirrors?Also i was told the mk3 astra plates would require slight modification. Can anyone remember exactly what modification is involved. Quote
Glanza_Ragger Posted April 27, 2007 Posted April 27, 2007 more than likely have to chop the baseplate down slightly mate, as its going to be slightly larger ;) Quote
Sparky Posted April 28, 2007 Posted April 28, 2007 Shaun had these on his Glanza rep I will get him to post on here when hes online next Quote
RoSsSr16v Posted May 4, 2007 Posted May 4, 2007 when screwing the back plates on dont screw on too tight or you will see almost like a dent on the backing plate and if screwed on too tight.... well il leave you to imagine the rest... all the best matey Quote
