pagey Posted April 27, 2007 Posted April 27, 2007 as some of you might no ive been having a problem with my glanza draining power ive now put a brand new battery on and it still was draining power so i fought the only other thing it could be was the alternator ive now had the alternator tested and thats perfect to but the car is still draining power any ideas? Quote
jon5698 Posted April 27, 2007 Posted April 27, 2007 have you got any electricals wired in on the switched power, instead of continous power, eg radio boost controler ect Quote
pagey Posted April 27, 2007 Author Posted April 27, 2007 have you got any electricals wired in on the switched power, instead of continous power, eg radio boost controler ective got a boost gauge with the power to it wired to the head unit cables Quote
Fogdoggydog Posted April 27, 2007 Posted April 27, 2007 That could be the problem. Some stereos are wired up so that they constantly have a power supply, but don't turn on until the ignition is turned. If it is wired into the constant power supply wires then the boost gauge could be be on permanently. Even if it doesn't suck much juice, over time will drain the battery. Take a multimeter to the cables in the back of the boost gauge and see if any current is flowing through it, no matter how small, when the car isn't on. If there is a reading then this could be the problem. Quote
pagey Posted April 28, 2007 Author Posted April 28, 2007 All sorted got an auto electrician on the case and found out there was a belt loose so its tight and all working even fitted my dumpvalve Quote
