Right just got a cv joint from camskill but it doesn't fit. It's the right spline count and fits the shaft and the hub but when I tighten the big nut it pulls the joint tight against the hub and won't turn. it also has splines on the outside of the joint. Is this for abs? I ordered one without abs and it says on the invoice without abs. It's the second one I've ordered and both came with the splines in the outside. Oh and I don't have ABS. can anyone help?
