RedlineShifter Posted March 11, 2012 Posted March 11, 2012 I know it's been asked before but I can't find a thread to help me.How do I de-wiper the Glanza? I have undone the bolt under the cover, what do I do next? Do I just yank it off or are there more bolt/nuts ender the rear panel?Thanks Quote
A L 3 X Posted March 11, 2012 Posted March 11, 2012 (edited) yeah it just pulls off iirc but needs some force and wiggling, also WD40 helps, you need to balance between force and not warping the bootlid, once thats off remove the motor from under the boot trim then use a 32mm grommet i think, ive got a bag of them somewhere if you need one. Edited March 11, 2012 by A L 3 X Quote
RedlineShifter Posted March 11, 2012 Author Posted March 11, 2012 yeah it just pulls off iirc but needs some force and wiggling, also WD40 helps, you need to balance between force and not warping the bootlid, once thats off remove the motor from under the boot trim then use a 32mm grommet i think, ive got a bag of them somewhere if you need one. Alright, thanks.I just can't get the clip off the rear panel, they just turn without coming off :/ Quote
A L 3 X Posted March 11, 2012 Posted March 11, 2012 If you can, hold the outer bit with your fingers, if not something like a sharp knife point to grip it but this will mark the clips, depends if you're as picky as me lol...then once youve got the outer bit secure turn the inner bit with the screwdriver but dont put much downwards pressure on, they're tricky but the centre bit should eventually unscrew, then just lever and pull the whole clip out :y: Quote
RedlineShifter Posted March 11, 2012 Author Posted March 11, 2012 If you can, hold the outer bit with your fingers, if not something like a sharp knife point to grip it but this will mark the clips, depends if you're as picky as me lol...then once youve got the outer bit secure turn the inner bit with the screwdriver but dont put much downwards pressure on, they're tricky but the centre bit should eventually unscrew, then just lever and pull the whole clip out :y:I've gotten 4 of the clips off, 1 just doesn't want to part the car. Do you know the part number for the clips? Quote
A L 3 X Posted March 11, 2012 Posted March 11, 2012 Hmm I don't mate, maybe worth ringing Toyota and describing it, two of my clips were difficult I had to spend about 5 mins on each one lol Quote
