StuDoc 72 Posted March 22, 2012 Posted March 22, 2012 (edited) Soooo after many complications i got a hold of a set of ep82 top strut mounts off Rory. When they arrived today i checked to see if my problem was solved and guess what still got the same issue so this time i have taken a few pics of the offender. So this is the top of the shock rod:So the issue is that the strut mount sits on the collar just nicely as it should. But the spring caps will only go over the threaded part as you see hereI have seen pictures of other peoples potenza shocks and it looks as though they are jus using oem spring caps so im puzzled as to why mines dont fit over the collar on to the squared bit as they should. Please help guys this has been dragging on for month cheers. Edited March 22, 2012 by StuDoc 72 Quote
