last time i serviced my other ep82 i used ngk irdium heat 8 spark plugs and fuchs titan 5w 40 that was for a ep82 running around 150 brake just wondering whether i should change any of the stuff for my new ep82 which is now forged running 270 bhp ? or should i stay the same?
If you've gone to all the trouble of forging your engine, you should be looking to use a very good quality oil. Nothing wrong with the other stuff, just not as good as the Pro S.
Wouldn't see any reason to change the plugs if they were ok before.
ive only recently bought the car so thought would change the plugs as they may not have been changed for a while and maybe an oil change bloke i got it off said it recently had an oil change but finding out what oil i need in advance so you recon one i got will be fine or go for the better one ?
