StarletMad Posted April 9, 2012 Posted April 9, 2012 On the back/bottom of the Inlet Mani there are two "outlets" about an inch apart do they go to the Brake "thingy" block on the Bulkhead.Its got like a "sender" type thing on it.Thanksss Quote
jayc-glanza17 Posted April 9, 2012 Posted April 9, 2012 the nearest one does, the other you can block it off like i have as its for air con i think...also if urs is a gt, then ou need the one way valve pipe from inlet to servo Quote
