hi there could any one help as want to remove boot loom the one that running along de wipered boot but third brake needs to work but is powering some things of the sunroof just want brake lights working and indicators that one runs on the along the floor just neating up and choping unwanted stuff .....HELP thanks anyone.......
too far away for me but only one wire only needed to go to the boot lid for the high level brake light as long as the boot frame is earthed to the rest of the chassis, just remove it all find out what wire goes to it, and make a seperate earth inside the boot lid frame is that what your on about?
you might be able to run the other rear loom inside of the panel???? unsure tho been a while since i looked at one
