Azz Posted April 15, 2012 Share Posted April 15, 2012 Can anyone point me in the rite direction on how to plumb in my wastgate plase ( vacuum pipes) , its only a cheap one as im still changing bits around.It will not be ran with a b/c at the moment.Cheers Aaron Quote Link to post Share on other sites
Azz Posted April 15, 2012 Author Share Posted April 15, 2012 anyone please Quote Link to post Share on other sites
Ryan-11 Posted April 15, 2012 Share Posted April 15, 2012 (edited) run a vacuum pipe from the turbo to the bottom pipe on the wastegate, it will boost to whatever spring u have in the wastegate Edited April 15, 2012 by Ryan-11 Quote Link to post Share on other sites
Azz Posted April 15, 2012 Author Share Posted April 15, 2012 run a vacuum pipe from the turbo to the bottom pipe on the wastegate, it will boost to whatever spring u have in the wastegateCheers budy but what about the top one ? Quote Link to post Share on other sites
Ryan-11 Posted April 15, 2012 Share Posted April 15, 2012 Cheers budy but what about the top one ?Just leave it as it is. Quote Link to post Share on other sites
Azz Posted April 15, 2012 Author Share Posted April 15, 2012 just open to the air like? Quote Link to post Share on other sites
Ryan-11 Posted April 15, 2012 Share Posted April 15, 2012 Yeah mate, it only gets used with an electronic boost controller.should look like this, apart from my vacuum goes to my inlet mani because i dont have a vacuum port on my turbo. Quote Link to post Share on other sites
Azz Posted April 15, 2012 Author Share Posted April 15, 2012 Ah rite i get you now, Cheers matey Quote Link to post Share on other sites
Flaminsam Posted April 15, 2012 Share Posted April 15, 2012 the top is to pre charge the spring pressure. so if your spring pressure is 0.8bar if you allow 0.2bar to enter the top it will give you 1 bar of boost pressure if you get me. you will need to pipe in a bleed valve or possibly a electronic boost controller. Quote Link to post Share on other sites
